Upgrading wheels? You'll need this!
There's a button or something behind the glove box as I recall from the owner's manual... :p ...But I'll check out the vid. ;)
images didn't show up. Open glove box switch is on left side. This is from 2017 manuel. This only works with orig. sensors. If you have changed them you will have to take it to dealer and have them register them.
446 7-3. Do-it-yourself maintenance
■ How to initialize the tire pressure warning system
  1. 1 Park the vehicle in a safe place and turn the engine switch off.
    Initialization cannot be performed while the vehicle is moving.
  2. 2 Adjust the tire inflation pressure to the specified cold tire inflation
    pressure level. (→P. 550)
    Make sure to adjust the tire pressure to the specified cold tire infla- tion pressure level. The tire pressure warning system will operate based on this pressure level.
  3. 3 Turn the engine switch to the “ON” position (vehicles without a smart key system) or IGNITION ON mode (vehicles with a smart key system).
  4. 4 Open the glove box. Press and hold the tire pressure warning reset switch until the tire pressure warning light blinks slowly 3 times.
5 Vehicles without a smart key system: Wait for a few minutes with the engine switch in the “ON” position and then turn the engine switch to the “ACC” or “LOCK” position.
Vehicles with a smart key system: Wait for a few minutes with the engine switch in IGNITION ON mode and then turn the engine switch off.
There lies the problem....
I bought all new sensors.
