V4.94 Digiprog III Digiprog 3 was one of the well-known OBD2 Odometer Correction Tool For full range or vehicle. V4.94 Digiprog III has a good reputation for its quality,stable performance,Multi-vehicles coverage and cheap affordable price.
And following is a autocardiag.com customer's personal experience sharing for its Digiprog 3,maybe it will be useful for members who needed it.
Original Post i quotated from
"V4.94 Digiprog III Digiprog3 i received was cheap affordable but top quality,for me,this is the best OBDII Odometer Correction Tool at cheap affordable price. The Digiprog 3 i received was a full set with all cables and adapters as following picture shows
Digiprog VIII can be connected with dashboard or OBDII to provide a full diagnostic for full range or vehicle with multi-languages optional .and i have tested on my Toyota RAV4,No Blue Screen problem,works perfectly.
Digiprog VIII V4.94 provides multi-languages available and it is easy to use, my good experience with Digiprog 3
1.Well made with great quality at cheap affordable price.
2.Full set,the package contains ST01/02 or ST04 Adapter.
3.Easy and stable to use, can be connected with dashboard or OBDII .
4.Provide a full diagnostic for full range or vehicle,like BMW,Toyota
BMW 3 Series E46 2000 35080 Chip Programming Via chip
BMW 3 Series E46 Bosch 35080 Programming via chip
BMW 3er / Compact / Z3 Cluster-Diagnosis
BMW 3er / Compact / Z3 up 98 Cluster-Diagnosis
BMW 3er / E36 Diagnosis
BMW 3er / E36 Modell 99 Cluster-Diagnosis
BMW 3er / E46 1999/2000 Diagnostic
BMW 3er / E46 Lightmodule HC11 Programming via Chip
BMW 5er / E34 Programming via Chip
BMW 5er / E39 up 05/99 Programming via Chip
BMW 5er / E39 with BC to 04/99 Diagnosis
BMW 5er / E39 without BC to 04/99 Diagnosis
BMW 7er / E32 Programming via Chip
BMW 7er / E38 (SW 12/13) up 05/99 Cluster-Diagnosis
BMW 7er / E38 (SW 14) up 05/99 Programming via Chip
BMW 7er / E38 to 04/99 Diagnosis
BMW 7er up 10/01 Only in our Office / In progress
BMW 8er / E31 Diagnosis
BMW All CAS Units Send to office
BMW E39 LCM Diagnostic
BMW E39 Light Module All models Diagnostic
BMW E46 2001/ Light Module HC12 Diagnostic
BMW E46 2003/ Light Module HC12S Diagnostic
BMW E46 LCM Diagnostic
BMW E50 5 Series 2004 Diagnostic
BMW E60 & E65 E90 2004 2007 CAS Diagnostic
BMW F650GS Programming Via Chip
BMW Key Module & LCM all models Progarmming Via EWS
BMW Still R70 Programming Via Chip
BMW X3 Programming Via Chip & EWS LCM Diag
BMW X3 LCM Diagnostic
BMW X5 (SW 14 High) Programming via Chip
BMW X5 EWS & Key Programming Via EWS
BMW X5 LCM Diagnostic
BMW X5 Light module Diagnostic
BMW X5 Light module HS12 Diagnostic
BMW Z4 Programming Via Chip
BMW Z8 Programming via Chip
Toyota Avensis Diagnosis
Toyota Avensis 2004 Programming Via chip
Toyota Camry Programming via Chip
Toyota Cellica Programming via Chip
Toyota Corolla Programming via Chip
Toyota Corrolla VDO Programming via chip
Toyota Hi Ace Programming via Chip
Toyota HJ 100 Programming Via Chip
Toyota IGNIS Programming Via Chip
Toyota K95 Programming via Chip
Toyota Land Cruiser 2003 C66 Programming Via Chip
Toyota Landcruiser Programming via Chip
Toyota Landcruiser 2003 Ch66 Programming via Chip
Toyota MR 2 Programming via Chip
Toyota Picnic Programming via Chip
Toyota Prado Programming via chip
Toyota Previa Programming via Chip
Toyota Prious Programming Via Chip
Toyota RAV4 Programming via Chip
Toyota Yaris Programming via Chip
Toyota Yaris Tsport Programming via Chip
So,from my experience,if you are looking for a costive but professional Odometer Correction Tool,then you can give Digiprog VIII V4.94 Full Set a shot,and it will never fail to you.
