Winter Tires 215/50R17 95V on Corolla S
Hi All,
I was hoping you can help me confirm the following:
I traded my old car and now I have a fairly new Winter tires in my storage.
Hankook Winter I*Cept Evo 215/50R17 95V.
It is already installed on a steel wheel rim.
Now that I bought a new car Toyota Corolla S CVT I would hate to sell my existing winter tires (only 2 winters old)
The new Toyota Corolla is a 215/45R17. Would this cause any issue if installing a 50R17 Winter Tire? I assume I just have to work on the TPMS?
Tire change in December and then put the all season tires in May.
http://www.rimsntires.com/specspro.jsp
Suspension clearance: The same.
Fenders clearance: The same.
Wheelwells clearance: Will fill out the wheelwell by extra 11 mm. Acceptable for most cars.
SPEEDOMETER: When speedometer reads 60mph (96.6km/h) actual speed will be 62.1mph (100km/h): 3.5% faster.
Tires should be fine. You would need to verify bolt pattern, hub centerbore, offset and width on the steel rims and replace TPMS if non-Toyota wheels.
Thanks for the quick reply! This is very info on the link you provided :thumbsup:
