Won't Start
OK, so I just changed my water pump. I forgot to unplug the battery, and I had the alternator cable arc to the header i think. Then I went ahead and undid the battery.
I get everything back together, battery back on. Open the door no lights. Go to start the car, and the horn/alarm starts going off. Pull the key out, it stops. Any ideas? Did I blow a fuse, or something worse?
I'm going to check fuses now...
Thanks,
100A Alternator Fuse is Blown
So far it appears that the 100A alternator fuse is my issue. Now I'm trying to get it out. Little luck. Thoughts, tips or hints?
