Xprog 5.72 XPROG-M Without USB Dongle Quick Review!
Last week, the NEW XPROG BOX ECU Programmer Series,called : Xprog 5.72 XPROG-M Europe Version was released and presented public. The Newest 5.72 Xprog BOX ECU Programmer has same look as the XPROG 5.70,but it is the improved version of XPROG 5.70 XPROG-M.
The different between XPROG-M v5.72 and XPROG 5.70
1.New XPROG 5.72 without USB Dongle,while the XPROG-M 5.70 comes with.
2.Compared to 5.70, 5.72 XPROG ECU Programmer added new authorization.
3. XPROG-M 5.72 is a real EURO VERSION!!
Generally speaking, XPROG 5.72 shared similar features,functions to XPROG 5.7,see XPROG FW5.72 EU first images below
Newest XPROG-M 5.72 Tested Reported shared by forum members
EURO VERSION!!NOT CLONE FROM CHINA CLONE!!!---true !
100% working!---yes !
No USB Dongle,No need activate or keygen!---True !
Directly use and can be connect with internet!!! --yes !
Stable Chips board connection---Yes !
For Multi-cars,no year limited.---true !
XPROG FW5.72 Supported Authorizations :
AUTH-0001 Motorola HC05 family authorization (allows to read/write EEPROM)
AUTH-0002 Motorola HC08 family authorization (allows to read/write EEPROM)
AUTH-0003 Motorola HC11 family authorization (allows to read/write EEPROM)
AUTH-0004 Motorola HC12, 9S12 family authorization (allows to read/write EEPROM and flash memory)
AUTH-0005 Texas Instruments TMS370/TMS374 family authorization (allows to read/write EEPROM)
AUTH-0006 Motorola HC05Bxx and HC05Xxx family bypass security authorization (allows to read/write secured EEPROM and flash memory)
AUTH-0007 ST M35080 authorization. Read/Write/Erase device to delivery state.
AUTH-0008 BMW EWS3 authorization
AUTH-0009 ATMEGA family authorization (allows to read/write EEPROM and flash memory)
AUTH-0010 MB ZGS001 authorization
AUTH-0011 Motorola HC11EA9/E9 bypass security authorization (allows to bypass security bit and read EEPROM and RAM memory)
AUTH-0012 National CR16 authorization (allows to read/write EEPROM memory)
AUTH-0014 ST7, ST10 family authorization (allows to read/write internal flash)
AUTH-0015 MPC5xx authorization (depending on device program automatically detects MPC5xx, M95xxx device type, flash, external flash and configuration memory size)
AUTH-0018 Motorola HC12, HC912, MC9S12, MC9S12X bypass security authorization (allows to read/write secured EEPROM and flash memory)
AUTH-0020 ARM (Micronas, ...) Family authorization (allows to read/write internal flash and external serial EEPROM)
AUTH-0021 ARM (Micronas, ...) Family bypass security authorization (allows to read/write secured and non-secured internal flash and external serial EEPROM, view/change mileage,chassis number (VIN), serial number and PIN code).
AUTH-0023-1 MAC7xxx
AUTH-0023-2 XC23xx
AUTH-0024-1 MC9S12Cxx
AUTH-0024-2 MC9S12XE
AUTH-0024-3 9S12XE SECURITY
AUTH-0024-4 MC9S12HA/HY/P
AUTH-0025-1 MPC/SPC5xxx Authorized 11/4/2014
Though XPROG 5.72 also has its limitations,like Only English supported,must be installed on the virtual machine and so on,yet,in general,it was still a good ECU Programmer to have in hand.
