Hi,
Just bought a 2002 Toyota Corolla CE for daughter - nice little car, rather grubby but a good spit and polish will cure that - has recent timing belt/chain and tensioner, starter, new tires, and oil change. It has not had a transmission oil change for a while and I am going to do that myself - couple of questions:
1. Any specific type of aft needed for this?
2. Is this a drop the pan to drain type or does it have a drain plug to get aft out first?
3. Going to buy a kit with new gasket and filter - any hints/advice about putting that in?
At last oil change they told po that the oil pan gasket was weeping - is this anything to be concerned about or ok to wait until next oil change to replace?
Small red flashing light under dash in footwell - po said was alarm system but no other information - should there be a way to arm this? Car has manual window winders and no central locking so no key fob alarm to set.
Has small spare road tire - is this original set up or should it have a full size?
Finally any other advice for things to watch out for, common problems etc?
Thank you
Lee
Thank you
Lee
