If you shut off a 2018 Corolla after it's really hot, and after you've been driving in high Summer temperatures with the A/C on. Will the engine cooling fan continue to run with the ignition turned off? I know the cooling fan is electric due to the transverse mounted engine. And there were some older vehicles, and liquid cooled motorcycles that were set up so the fan would continue to operate with the engine off until the coolant temperature dropped enough.
I live in Arizona, and several older vehicles that were set up like this could kill a battery in no time if you parked a hot car in a hot garage in June, when the temp was in the 115 F+ range. I've heard most new vehicles have done away with this type of cooling system. And I just wondered what the new Corolla's have in regards to this? Thanks in advance, as I really appreciate all of your helpful insight.
