I was wondering how does the Car Ride after Lowering it ? Does anyone have Regrets after installing TRD Lowering Springs ? Thanks in advance for ant responses.
 The TRD springs are a dealer installed  option, so they’re engineered to work with the suspension.
With that said, it will give you a stiffer ride and better handling but, I personally think the springs could be even stiffer. They’re kinda soft.
I only know this because I recently replaced mine with coilovers. Much stiffer!
It rides like a properly lowered car. You can feel every pebble on the road! Lol
But it’s not uncomfortable.
I have no regrets with either set up. Each has its own set of characteristics if you will.
I switched to coilovers for a couple reasons. Above I said the TRD springs were too soft. What was happening to me is when I put two kids in the back seat, with subs, amps and a little luggage, the back would sit much lower than the front. I wanted coilovers so I could have some adjustment.
I also wanted to be able to adjust the dampening. I noticed the rear would squat when I would take off under hard acceleration.
The coilovers have eliminated these two problems for me. I have the rear so stiff that I could add a sumo wrestler and it still wouldn’t squat!
