DIY of PWR steering Rack N pinion project. Some suggest dropping the subframe partially, some suggest remove subframe completely! Both way I have experience PROs and Cons! Details info and Pics will be posted for update!
Tools for DIY:
10, 12, 14, 17, 19mm sockets, wrench, and all size extension
1/4", 3/8" ,1/2" ratchet and 1/2" toque wrench (up to 200 ft lbs)
1/2" impact gun (remcomment) and 3/8" air ratchet (optional)
17mm & 19mm impact socket
Specialty wrench (17mm flare nut wrench or crowfoot socket)
22mm deep socket ( power
steering pressure line switch)
measure tape and whtie out for reference marking
1/2 qt power steering fluid or Dexron ATF
Loosen the power steering pressure line to drain the fluid with 22mm deep socket!
Tools for DIY:
