I have a 1999 corolla and the clutch needs replaced at 193k miles. After much research I want to get OEM Exedy clutch but have found a problem of which to get.
I have noticed that some OEM clutches have the input shaft size as 15/16" and others 1" and disk sizes ranging from 210mm to 213mm.
I need to know which will fit.
2003 exedy TYK1501
or
1999 exedy KTY03
I would like to use an 2003 clutch due to it being larger and using the same flywheel as the 1999.
213mm compared to 210mm but don't know of it fits.
Please help me if you know what fits.
I have used the "search" but only thing I find is that several people have used LUK clutch kits.
summary: 1999 corolla OEM clutches sold as both 15/16" shaft and 1" shaft. Sold with 210mm disk all the way to 213mm disk. Car shares same flywheel as 9th gen corolla. Which is right for my car?
2003 exedy TYK1501
or
1999 exedy KTY03
