2001 Corolla Driving Me Nuts
Help
I have replaced the cat converter, upstream and downstream 02 sensors, air filter, ign coils and spark plugs, MAF sensor, replaced intake manifold gasket, cleaned the throttle body, checked for vac leaks (none), replaced the gas cap on my 2001 Corolla. I have no more random misfire codes but still have a 0171 code. What can I do? Thanks
code P0171 may mean that one or more of the following has happened:
  • The MAF (Mass Air Flow) Sensor is dirty or faulty
    Note: The use of "oiled" air filters may cause the MAF to become dirty if the filter is over-oiled. There is also an issue with some vehicles where the MAF sensors leak the silicone potting material used to protect the circuitry.
  • There could be a vacuum leak downstream of the MAF sensor
  • Possible cracked vacuum or PCV line/connection
  • Faulty or stuck open PCV valve
  • Failed or faulty oxygen sensor (bank 1, sensor 1)
  • Sticking/plugged or failed fuel injector
  • Low fuel pressure (possible plugged/dirty fuel filter!)
  • Exhaust leak between engine and first oxygen sensor
lot of times, cleaning the MAF sensor and finding/fixing vacuum leaks fix the problem. If you're on a tight budget, start there, but that may not be the fix for certain. So, possible solutions include:
  • Clean the MAF sensor. Consult your service manual for it's location if you need help. I find it's best to take it off and spray it with electronics cleaner or brake cleaner. Make sure you are careful not to damage the MAF sensor, and make sure it's dry before reinstalling
  • Inspect all vacuum and PCV hoses, replace/repair as required
  • Inspect all hoses and connections in the air intake system
  • Inspect and/or test the intake manifold gaskets for leakage
  • Check for a dirty fuel filter and proper fuel pressure
  • Ideally you'll want to monitor short and long term fuel trims using an advanced scan tool
  • If you have access, you may want to run a smoke test
Help
Why were all those parts replaced? They were all bad?
