Daughters 2002 toyota corolla makes a rattly/knocky noise at start up when cold - also seems to make this noise at med high rpm acceleration - noise appears to be coming from the serpentine belt area - is this the tensioner making the noise? I have a reciept from PO for tensioner replacement for $125 from a couple of years ago - could this be failing again so soon? Mechanic said he could also hear a noise from water pump - quoted $790 to replace tensioner, new water pump and new gaskets - car runs perfect and is in good shape - has 140 K Not sure if to keep running it for a while or get this work done now.
Thank you,
lee
Thank you,
lee
