I have a 2002 Corolla engine that has had a pinging type noise sounding almost like a vibration from a heat shield. I've put up with this noise for about 50,000 mile. 2 month ago I replaced the valve cover gasket and I could see the timing chain had some play in it. Recently the car just died out. I know it's getting fuel. My guess is the timing chain jumped and now the valve are off timing. I need to get a compression tester and see if I have compression. If the compression isn't right I will assume the timing chain needs to be replaced. I'm sure there is a post in this forum someplace about replacing the timing chain but I have no idea how to find it. I feel with the valves tapping those 50k miles I will have the head rebuilt incase the valve guides and or valves got screwed up from all that time. I need a post on how to remove and replace the cylinder head.
