ok so it shifts good to 2nd 3rd 4th and 6th, some times when i down shift to 5th from 4th it will grind a little, and if im downshifting from 6th to 5th it will grind, other then that it runs good and shifts ok.. also what i noticed is if i rev it a little bit to shift to 5th from 4th or 6th to 5th it does not grind a bit weird but i will double check that and let you guys know
