Hi all, I'm new here and new to Toyota (have owned 2 Subarus, a Honda and a Mazda in the past) having purchased a 2005 XRS in June of last year (2014). So far I really like the car, it's perfect for around town and I gotta say I am almost in love with it. Only thing is it's developed some smaller issues over the last two or so months that right now are just starting to really become constant and I want to figure out what is going on before it leads to something more serious. Here is what it is doing-
-Car stalls sometimes when slowing down, same thing each time. Clutch pedal is on the floor anticipating the downshift, speed is around 15mph and decreasing, and then engine stall. No feeling or sound of engine cut always just the dash lights lighting up and/or the feeling or losing power steering is what alerts me to it. It sounds ridiculous but heading downhill, and especially heading downhill while turning to the right, increases the chances of this happening. Most times this is while I am actually still driving in traffic and not slowing for a traffic light, so I restart the car while it is still rolling with the clutch in and simply complete the shift as it starts back up and all is well (just weird and a little unsettling).
-Accelerator sticks. Not in the open throttle position, but if I have my foot on the gas and let off completely and then put my foot back on the pedal the pedal won't move unless I apply more pressure and then it sort of 'pops' for lack of a better descriptor. It will do this at traffic lights also for example in a fully stopped position, I'll go to drive away and the pedal will be stiff and not give until it breaks free with slightly more weight and then moves freely after that until it does it later down the road. Again it's fine but just weird and unsettling. There will probably be a time when this causes the car to launch into a car in front of me while driving but so far the lack of low end torque in this Corolla means it's pretty tame each time.
-Car stutters and stalls when in first pulling away from a standstill. As if it isn't getting enough gasoline (almost like someone just learning to drive stick and not giving it enough gas for fear of launching), I have gotten used to feathering the clutch and 'double tapping' the gas to get the revs up before I pull away from stop signs and lights because it likes to bog down unless I do. I thought that maybe this car just didn't have any torque at idle and required some sort of more effort to drive it but a few months back I got a chance to drive a regular (1zzfe engine) manual Corolla from the same year and it was effortless. More buttery and very painless to pull away or drive around compared to what I have gotten used to.
-Gas mileage is pretty questionable over the last 6 months. When I first purchased the car it was in another state and I had a 6hr (334 miles) drive to get it back to home base. It made it on one tank of gas despite going through a fair amount of long hills through the Cascades. When I got home and filled the tank I calculated it out and it was 34.6mpg. Now I wouldn't expect this regularly, for the most part I drive in the city and I am only on the freeway for a few moments to hop on and off, but I was expecting around 26mpg city. Typically though it is not at all unusual to fill up at my usual 1/4 tank mark with ~200-210-220 miles (20-22mpg), and I have even seen 19.2mpg recently. I have the 'performance' 2zzge engine and although I do drive spirited and probably hit the lift point once or twice a day (which snaps the car into hard pull near the redline) when getting on the freeway I'm not pedal to the metal racing around in between. I typically cruise around in 4th or 5th gear at 2k-3k rpm.
Any thoughts on what could be causing these or if they are related?
