2010 Corolla horn - modification
Discussion in '2009 - 2013 Toyota Corolla' started by Peter Tarantelli, Dec 6, 2017.
  1. Peter Tarantelli
    Peter Tarantelli New Member
    I have a 2010 Corolla S - I also have a 2001 Tacoma SR5. I like the Tacoma's horn much more than the Corolla's. Has anyone here replaced or somehow modified their Corolla horn to make it louder with a deeper tone?
  2. Corolla Forum Sign Up!
  3. stvotw
    stvotw New Member
    horn circuit is 10 amp. If you swap with any horn with less than a 10 amp draw it will be basically plug and play. It might need a different style connector. If you get a horn with a bigger draw you will need a relay and a heavier power wire.
  4. OP
    Peter Tarantelli
    Good info! Agree on the plug n lay comment. I think there are actually TWO horns on the Tacoma (a low note and a high note). I can't imagine I'm the first to ever consider doing this.
  5. stvotw
    stvotw New Member
    [​IMG] I added dual horns to my Corolla. I hated the dinky 'meep" of the stock horn. I did mine when I changed headlights but it can be done without taking the bumper cover off. Look where the stock horn is mounted, about the same distance from center toward the passenger side is an unused mounting hole. It works great for the 2nd horn and uses the same size bolt as well.
  6. OP
    Peter Tarantelli
    Exactly! Did you use the same horn as the original? I assume you simply ran a wire from the stock horn to the second?
  7. stvotw
    stvotw New Member
    I changed over to a pair of Wolo horns. I used the stock horn wire to trigger a relay as the manufacturer stated a 15 amp circuit was needed. If you have less than a 10 amp draw with an additional horn you could just run a jumper wire from the first horn.
  8. Toyota for life
    Toyota for life New Member
    I put Tundra horns in my Corolla. I bought the HELLA 012010901 because they come with Toyota connectors so all I had to do was build my own pigtail to run from the original horn connector to both horns.
  9. OP
    Peter Tarantelli
    Thanks...I haven’t done anything yet but I’ll check that out!
  10. Toyota for life
    Not a problem. Gimme a holler if you have any questions. If you go to amazon and look up those horns, I posted a video there.
  11. OP
    Peter Tarantelli
    Just saw the video...nice and thanks!
  12. fishycomics
    fishycomics New Member
    Awesome job. over the years I been thinking, never did get around, but did change a horn. I simply make up the wiring connector and done. Years ago it used to be air horns no more those days for me are over Lol again great to hear you got new horns on her
    Toyota for life likes this.
Share This Page
