2012 Corolla LE - Foglight Kits
Scott O'Kashan
Good idea and I second that. :thumbsup:
If you have an Advance Auto Parts or Autozone in your neck of the woods, they should be able to help you out with the real amber fog lights.
Found a custom shop that will get the toyota fittings to go in the spot (from an auto body supply that furnishes parts for damaged cars). They'll wire in a good switch so when in low beam, I can select them on, high beams cuts them off- just like the factory set-up on my Tacoma. Thanks!
Scott O'Kashan
Those are white lights, not amber fog lights. Amber is what we want to cut through fog better. White light is terrible in the fog. :(
Marketers refer to add-on white driving lights as, "fog lights", but they are not unless the lens is amber in color.
