2014 Corolla - Shorted ACC Line
Guys, I need help.
I am trying to install headrest monitors in my 2014 corolla. For power, I tried to tapping into the ACC line that's located in the ECU under the steering wheel. I verified that the tap was working by measuring voltage when I turned the key to ACC. After that, i tried securing the wire. While trying to secure the wire, the other end of the exposed wire touched a screw and I saw a spark. So I knew I shorted it. Now when i turn the key to the ACC position, nothing comes on, no radio, no nothing. I can't even drive the car now because there's a bunch of lights that go on and stay on when they're supposed to go off.
Does anyone know the fuse to the ACC is? Did I just burn a fuse or something else? I checked all the fuse in the engine bay but they're all fine.
Can anyone help please?
Guys, I need help.
How did you check the fuses?
One way to check the fuse is to replace it. As far as I know, there are 2 or 3 fuse boxes located in the car. One by the driver, one possibly by the passenger seat, and one inside the engine bay.
Thanks for the replay man. There's a fuse box right under the ECU that's under the steering wheel. Each fuse has 2 little holes at the top, so I probed them to find out which one blew. Even though I shorted the ACC line, the ACC fuse didn't blow. There was a 5A fuse that blew, I replaced that and everything works again.
Now when i turn the key to ACC my headrest monitors come on. Cool!
Make sure all the wire connections and solder joints, etc. are properly insulted. Spend $6 on eBay and buy a box of heat shrink tubing. It will last you a life time lol.
