2017 Headlights
Discussion in 'Toyota Corolla Maintenance' started by Shayne, Nov 27, 2017.
  1. Shayne
    Shayne New Member
    Hello everyone,
    I was wondering if someone could tell me how I could access the low beam and high beam bulb on my 2017 corolla se. I am trying to place a Hid on my low beams but cant locate the low beam.
    Pictures or videos would be very much appreciated.
    Thank you
  2. Corolla Forum Sign Up!
  3. Ki6pyr
    Ki6pyr New Member
    Low beams are led and can only be replaced by replacing the entire assembly I believe.
  4. echarleswhyte
    echarleswhyte New Member
    I believe on the SE 2017 BOTH low and high are LED.
  5. OP
    Shayne
    Shayne New Member
    I know they are LED but I'm wondering, how I get to the bulb so I can take the low beams out and place a HID kit in.
  6. echarleswhyte
    I am not an expert nor will I claim to be one. However, factory LED lights are not the same thing as a replacement LED bulb you buy on e-bay. What you see on e-bay is meant to replace an existing bulb technology. While factory LED lights are a system, not bulb you can just remove and replace. So as mentioned before you will likely have to do serious surgery to the housing to remove all the LED lights and then build yourself a base where you can mount HID. Maybe in time you can buy the HID housings on line and just replace the whole thing. However, I personally don't think anyone will bother as LED technology is better than HID hence why manufacturers are moving on from HID and into LED. Heck BMW is moving from LED to Laser light technology. I believe there was a reason why the Corolla went from halogen bulbs straight to LED skipping HID all together. Anyway this is just my opinion on the matter.
Share This Page
