2020 SE Manual 6-Speed Likes & Dislikes
I'm going to keep a running list here of the things I like and don't like. Some items will appear in both categories, because there are aspects of some things which are both good and bad.
Exterior style. I thought it was OK when shopping, but it's really grown on me. I've seen a lot of complaints about the large-mouth-bass look of the front grille, but that's something that hasn't bothered me at all. I think it's less noticeable on the darker colored cars. The 18" wheels look very nice, and I've received some compliments on them already.​
Interior Dash Design. The dash layout is definitely minimalist, and I like that a lot.​
Interior Comfort. The longest I've been driving at any time is maybe 1.5 hours, but I found the seats and seating position to be reasonably comfortable. I'm a little over 6 feet tall, and when I lower the driver's seat I have plenty of headroom. The backseat legroom and headroom is better than I expected.​
Handling. The cornering (at least on the SE) is surprisingly flat, especially for an econobox. I've pushed it fairly hard around corners at speed, but not hard enough to lose traction on the still-new Dunlops. The torque-vector braking effectively eliminates understeer, making turn-in feel surprisingly (almost unnaturally, see 'Dislikes' below) quick when cornering hard.​
Manual Transmission. It's simply a lot more fun to drive a car with a MT -- even an econobox.​
Engine. It's not the most spirited sounding engine, and it feels a bit reluctant to rev at times. Almost like it has a heavy flywheel. But a big part of that is that the fly-by-wire accelerator is calibrated conservatively such that more pedal travel is required than expected. Once I got used to giving it a bit more pedal, it gets around pretty quickly when needed. Again, having a MT allows finer control over the RPM/available torque, and that helps get the most out of this engine.​
MPG. So far, so good. First tank was 36-37 MPG, and second tank looks like it will be 40-41. Mostly rural driving at 25 MPH - 45 MPH.​
Dislikes:
Noise. I'm not sure whether to blame the Dunlops, the lack of sound-deadening materials, or both. Especially when the tires are cold I hear and feel a subtle bump-bump-bump of the front tires while turning. At 30 MPH the road noise is noticeable, and it borders on annoying at highway speeds. The wind noise isn't severe, but it's definitely noticeable at highway speeds. On a recent ride into the city on some bumpy roads, there was a persistent buzzing rattle somewhere around the driver's side door frame or headliner between the A and B pillars.​
Ride Quality. Over perfectly smooth pavement it's really nice. Over typical/decent roads it's acceptable. Over bumpy roads it ranges from OK to fairly jarring. I think in Toyota's zeal to make the SE "sporty enough", they favored aesthetics over practicality with the 18" wheels and 40r/18 tires. I think 17" wheels and a little more rubber would have been a better choice, and sufficient to distinguish it from the non-sporty trims. I have 16" wheels with 205/55r/16 tires for winter driving, and it will be interesting to see how the ride quality improves with these. I'm sure some of the...stiff/harsh ride quality is due to the suspension tuning.​
Handling. While I appreciate the torque-vector braking, it takes some getting used to. It seems like it doesn't always come on smoothly/progressively. If you're in the middle of a sweeping turn and then turn a little sharper, the vectoring system seems to kick in kind of abruptly. When this happens, you suddenly go from a predictable, mildly-understeering FWD car, to a "Holy @#%! I'm oversteering!" kind of feeling. If you're not prepared for this it's alarming at the least, and potentially dangerous. I've had a few times where the car was understeering a bit during a high-speed entrance ramp curve, and I was reluctant to turn any sharper for fear that the sudden switch to oversteer would cause me to lose traction. It can sometimes give the perception of a sudden shift in direction that might make you lose control of the vehicle, or even rollover.​
Clutch/Shifter. The clutch engagement point is too high. It takes a bit of getting used to, and until you do it's actually easy to stall the car when starting out in 1st. This is exacerbated by the large amount of accelerator travel needed before enough fuel enters the system. The shifter was butter-smooth at first, but now it's sometimes a little hard to get into 1st gear.​
Infotainment. Sorry, Entune 3.0 stinks. It looks boring, is laggy, and isn't particularly intuitive. The best I can say is that, for the most part, I've figured out where to go to find relevant information. Toyota promoted Alexa integration and Remote Connect, but neither of those are available as part of the regular Entune 3.0 system. The only thing on the infotainment system that I use is Apple Carplay and the Eco/MPG screen.​
Lane Tracing Assist. Again, Toyota marketing fail. Lane Tracing Assist is strangely missing on the 6-speed manual version. It's not a feature I anticipate using, but it bothers me that it's not there.​
Oops, I didn't realize you can't edit posts here. So much for the running list! I'll just have to add new items as replies.
Dislikes:
HVAC Controls. Too small, hard to see and find the setting I'm looking for. I'm sure this will improve as I memorize the layout. Also, there is a long lag between turning the fan speed setting and the fan actually responding. Like a couple seconds. That's pretty annoying.​
Dislikes:
Storage. Small glovebox, small center console cubby, and small phone tray. Cupholders are too narrow for most of my coffee mugs and water bottles to fit properly. Also, I swear I saw several youtube video reviews where the center console armrest slides forward on the SE (not just XSE) model. Not so on my SE model. Is it another feature not available with the manual transmission?​
My main dislike about my 2020 Corolla SE Sedan 6-MT is the key-less ignition system in general. I would rather have a regular key w/remote lock/unlock buttons like my 2015 Yaris SE 5-MT had. I would also rather have a regular pull-brake parking brake over the electronic parking brake nonsense. Lots of stupid, useless, gimmicky tech-bloat in modern cars IMO, a lot of which is only useful for distracted, stupid, intoxicated or otherwise impaired drivers. A factory dash-cam would have been more useful than the stupid lane-keeping-assist feature, camera sensor that reads speed limit signs, etc.
Did your J-VIN Corolla come with Dunlop 225/40/R18? Mine came with Yokohama 225/40/R18.
My main dislike about my 2020 Corolla SE Sedan 6-MT is the key-less ignition system in general. I would rather have a regular key & remote lock/unlock buttons like my 2015 Yaris SE 5-MT had. I would also rather have a regular pull-brake parking brake over the electronic parking brake nonsense. Lots of stupid, useless tech-bloat in modern cars IMO, most of which are only useful for distracted, stupid, intoxicated or otherwise impaired drivers.
Ugh, I forgot about the keyless ignition. The main reason I don't like it is I can't shut the car off at a stoplight without cutting accessory power (including the blinkers). So -- ignoring for the moment that it's illegal to do so -- I can't optimize MPG by shutting off the car at a long stoplight when I'm waiting to turn. Not to mention I can't do engine-off coasting, ever. If you try to hit the ignition off button while coasting, a message comes up on the screen warning me that if I press the button again, the car will perform an emergency stop. What the?
Totally agree about the auto e-brake as well. I despise that thing. The Hold feature can sometimes be pretty useful though. Probably more-so for someone getting used to driving a MT.
I do like the automatic climate control system & look/feel of the controls in general, but you are right that the buttons & text are small & require some active scrutiny to see which button is which & such.
Are you in the U.S.? My 2020 Corolla SE Sedan 6-MT has the useless lane-keeping-assist feature. It can be set to off, warning only, or warning+corrective action. I have it set off. Same with the stupid feature that reads speed limit signs & such. Toyota should just ditch those gimmicks & actually add somewhat useful standard safety-sense features on models trims lower than XSE - like side-mirror blind-spot monitoring (which would at least be somewhat useful if you have a cramped neck that week ;)).
Yes, US. The Lane-Keeping-Assist is a gimmick, but at least I can shut it off. :D What bothers me is that the manual doesn't have the Lane Tracing Assist like the CVT does, even though the equipment is all there (see LKA). Would I use it? No, but why is it missing? I don't get it.
I don't mind the speed limit indicator. There have already been times where I was driving somewhere new and missed the speed limit sign, and there it was on the dash. Yay.
Toyota should just ditch those gimmicks & actually add useful standard safety-sense features like side-mirror blind-spot monitoring (which would at least be somewhat useful if you have a cramped neck).
True blind-spot monitoring would be a useful improvement for sure. Overall I think TSS 2.0 is overrated -- same with Honda Sensing when I was shopping the Civic, though at least it provided a side-view video on the infotainment screen when turning right.
I agree with you on the 17" wheels, like what the Corolla iM was using. Seems like the sweet-spot for wheel & tire size for a car this size. 16" alloy wheels looked perfect on my little 2015 Yaris SE hatch, but the same 16" wheel size on the 2019+ Corolla SE hatchback (& sedan if it was ever used there) look too dinky & comical for the size/length of the vehicle. The 2020 Corolla hybrid sedan with the 15" wheels is REALLY comical looking :p. I would have loved to see the same 18" wheel design used for the XSE Sedan/Hatch & SE Sedan been implemented as a 17" wheel instead with 45 or 50 size profile tires. The 18" wheels & 225/40 tires just transmit too much road noise & poor ride quality on crappy roads - and there is NO shortage of crappy roads vs good roads it seems like (at least around here in PHX, AZ).
I got a set of 16" wheels with 205/55R tires for my winter setup. Combined with the softer rubber compound, I'm expecting a very cushy ride (by comparison). It will probably be jarring -- literally -- to go back to the stock 18-inchers when I switch back in March or so.
Yes, I realize the idea of winter wheels/tires is probably absurd to someone living in Phoenix. :D
^^ It even occurred to me that I might be able to sell the 18" stock rims/wheels to someone locally for a pretty penny. If I could do a straight-up trade for a good quality aftermarket wheel, I think I'd go for 225/55R17. Maybe the 55R is a bit tall aesthetically, but I think it would still handle fine (with the right rubber) and the ride quality would be far better.
My Yaris SE was 195/50-R16 & the 50 profile tires was the sweet spot between sporty lower-profile looks & ride quality. I checked a wheel/tire calculator some time ago & 215/45-R18 tires on our 18" factory rims would hardly affect the MPH readout at all (actual 65 MPH would read as 64 MPH on display). It was something I was considering for my next set of tires on my '20 Corolla SE Sedan.
Dislikes:
Sounds like handling is awful. I'm debating between a 2020 Corolla with a manual or a 2020 Hyundai Veloster N with the Performance package. If the Corolla is livable, I would consider saving the money and just getting a Corolla for now. However, If it's not really worth it, then I would like to go for the Hyundai.
I actually think the handling is good, and probably very good compared to previous Corollas. True, the torque-vectoring took some getting used to, but I've adapted. Think of it kind of like very sensitive/grabby brakes: until you're used to it, it's hard to modulate the pedal without stopping way too aggressively.
I have no idea about the Hyundai Veloster. I imagine the Corolla is going to be a better car in the long run (i.e., it will keep running well long after the Hyundai dies), but if the Veloster is performance-oriented and that's a higher priority for you, then maybe that's where your money should go.
Personally if I were a little less concerned about reliability but still wanted a solid economy car with excellent handling, I'd look at the Civic SI with 6-speed manual. I don't like the turbo + GDI combo, but if that doesn't bother you, it's a really great car IMO. Or consider
I shelled out the $200 Toyota OEM parts blood-money & purchased the hood insulator molded-fiber piece & 6 clips that should have been standard on the SE to begin with, just like it is for the 2.0L XSE. Heck, even my 2015 Yaris SE hatch had that standard from the factory for its tiny little hood & 1.5L 1NZ-FE engine. Besides fixing the tacky, unfinished, naked look of the underside Corolla hood, it also deepens/muffles the sound of the 2.0L engine properly so that it doesn't sound so hollow & whiny. Much happier with it installed. :)
Oh, that's cool! I didn't know you could order these parts. A shame it's $200, but OEM parts are often like that. I think the cheap, undersized, plastic door sill protectors with "brushed aluminum" finish were around $150. Ridiculous.
How heavy is the hood insulator? Was it easy to install?
I still think the infotainment system is unimpressive. But recently Toyota surprised me by sending me an e-mail letting me know that my Entune system was now compatible with the Toyota + Alexa app. I guess they rolled out an update? It works, though the app isn't the greatest. Still it was a nice surprise.
I just wanted to mention that my car is a BEAST in the snow/ice with the Blizzak WS80's. Granted, having dedicated snow/ice tires makes a big difference on most cars, but I've never felt this secure driving in the winter. Other than hating how dirty my car gets in the winter, I absolutely love driving in the snow and ice now. It's a bit of a game to see if I can actually break traction for more than an instant.
On a related note, the car is a lot more enjoyable to drive on the softer rubber compound and higher profile (I went with 16" wheels and 55R tires). The handling isn't quite as precise, but I like it enough that I'm seriously considering trading/selling my stock 18" wheels/tires for a 16" set that I'd use year-round. I bet I could get a lot of $$ for them from the owner of a non-SE Corolla who doesn't know any better. :D
I use mine as mostly a commuter. I like the ride don’t mind the tire noise reminds me of my 77 280z. I was commuting with a Honda Fit. If you think this is loud inside I couldn’t even use the phone in the Fit. It feels solid interior is pretty upscale feeling given its 20k. I have owned quite a few Mercedes,bmws and Audi s4’s. While not as nice as the higher end it’s just as good as the 1 ,2,and 3 series bmws as far as finish goes. This is not a civic si but those are more sound than speed. Sounds like you are fast but more sound than actual speed. Be interesting to have a side by side with a civic manual. My fit sounded like it was a race car lol but wasn’t going anywhere. I just bought a 2020 tacoma off road manual and it it quite and smooth can run over anything. Save the manuals !!!!!
