AC suddenly stopped
I have a 2009 Corolla S. The AC suddenly stopped working. The AC clutch is not engaging. i thought it was a relay but I have not located it yet. On older models it was in the fuse box labeled MG/CLT ?
2) I do see a two wire lead connecting to the end of the compressor, is this where I would test the voltage for the clutch? or is there a lead between the clutch and compressor?
3) I have yet to see the cooling fan kick on could this be related?
Have you checked to see if there is a sufficient refrigerant charge?. You may want to start there so you'll know if the refrigerant is low or leaking then you can proceed from there.
