Hi all!
The car runs ok, no problem at all except for this new issue. During the day, with all lights off, if I turn the key to listen radio or when the car is running, all lights start flickering as if I was turning the headlights on and off very fast (but I'm not). I tried to turn the headlights on very slowly, searching for some bad contact in the knob, but didn't find nothing. When the daylight running lights turn on, the dashboard lights dim down and the radio lights turn on, then the opposite, very fast, like 2 times per second, but randomly, not with a constant rhythm.
If I turn on the headlights (daylight running lights, high or low beam), it stops.
I also opened the fuse boxes and pushed every fuse in, no success.
Any thoughts?
Thank you!
Any thoughts?
Thank you!
