I have a 1991 Corolla DX with the 4A-FE engine. Recently I have two electrical problems that appear to be related, because they both started happening at the same time. The alternator will - on an intermittent basis - overcharge the battery. I have replaced the alternator (and integrated voltage regulator) and the battery. I have also checked the ground cable and the positive cable from the alternator. But I still have an intermittent overcharge condition. The second problem appears to be with the ignition or fuel system. The car idles rough, hesitats and surges at lower RPMs. I have replaced the plugs, wires, distributor, and oxygen sensor. But the car still has problems. Can a single, faulty component be causing both problems?
