ATF mixture in manual transmission?
Seriously a series of car faults these days....
I went for a manual transmission fluid change. I brought my own gear oil. After draining my transmission of the old oil, it was time to fill in the new. The worker used a machine that was meant to flush ATF to pump my new gear oil into my gearbox. I wasn't sure if that was the standard procedure, so I kept quiet but made sure he flushed the machine thoroughly. And I did ask him to run the machine through with more fresh gear oil.
Long story short, after pumping out the ATF and running with gear oil for a bit, the fluid coming out was still a bit pale red. Only halfway through filling, the fluid turn to the colour that a gear oil suppose to have (dark yellow gold). There may be a bit of ATF in my transmission now.
Is there any adverse effects? Will it damage or shorten the gearbox lifespan? For the record, I'm using a C160 6 speed synchromesh transmission.
