Recently my 1999 Corolla BRAKE light on my dashboard come on when I'm driving / accelerating , then when I brake it goes away. But it comes back on sometimes and goes away. What is wrong with my brake?
The emergency brake handle is already released. When I looked at the brake fluid container under the hood it is at minimum, maybe a little bit below minimum so I'm guessing it needs more brake fluid.
So I went to Auto Advance and bought
Valvoline DOT 3 and 4 Synthetic Brake Fluid.
My question is what are the steps I need to do to refill the brake fluid?
I googled and notice you have to flush or bleed the brake fluid? How do I do that? I don't have a front yard or garage and my car is parked in the streets so I can't do major auto repairs in the street. I can't just jack up the car and remove all the tires to bleed the brakes.
Is flushing or bleeding the brake fluid a lot of work?
Or should I just use a turkey baster or syringe to get some old brake fluid out of the brake fluid cylinder and pour in the new brake fluid?
Or should I just simply pour and max out the brake fluid without removing the old stuff?
