I have a 2005 S model, 1ZZFE engine that was seized and replaced in July. The head was inspected and deemed undamaged and re-used with a new 1ZZFE block from an engine builder that was bored 0.020 oversized with 0.50mm pistons to fit the new cylinder diameter. At the time, the dealer performed a valve job as well as replaced the spark plugs, thermostat, water pump and serpentine belt. I picked up the car and less than 4 hours later the engine suffered severe failure again. The dealer found that 3 of the 4 plugs were missing all or parts of the side electrodes and were severely "burned" around the edges. One of the piston heads also has a piece missing as well as scoring and gouging in the cylinder wall. Any thoughts on the cause? Thanks.
