bad day. drop the shifter 3 clicks down or if you did that and not moving and you engine running. turn it off call a mechanic. if it finds its way into gear. check fuse's relays etc. work your way to the mil lamp. but most modern cars have a fuse fail safe for this sort of thing. unless you bypassed the fuse pannel you should find that your fuse from your + battery terminal to the fuse box usually 50amp or so has done its job.
