Change wheels size??? 2018
I would say yes. The se does not have any bigger brake calipers so there should be no clearance issues. Toyota is not going to develop different hubs and all the associated components on the corolla. The only thing I can think of is the speedometer calibration may be different between the two different tires sizes.
Then you should be able to put in a 16" LE tire/wheel combo into an SE ;)
this is what I was getting at. using the wheel and proper tires size in combo will fit. However if the diameter is not the same it will throw the speedo off as it will be calibrated for the larger wheel and tire size.
Sidewall Radius Diameter Circumference Revs/Mile Difference
205/55-16 4.4in 12.4in 24.9in 78.2in 811 0.0%
215/45-17 3.8in 12.3in 24.6in 77.3in 819 -1.0%
this is minor in comparison so should not be much of a difference
