Clutch Pedal Extender
Hi all! I love driving my manual transmission Corolla '14. I'm 5' 2", so to press down the clutch all the way, I have to sit really close to the wheel. Getting in and out of the car is a bit awkward.
I've been looking into these pedal extenders:
1. Mustang clutch pedal pad extension http://www.latemodelrestoration.com/item/LRS-EZ9414/Mustang-Clutch-Pedal-Pad-Extension-94-14
2. Pedal-mate
http://www.discovermymobility.com/store/drivingaids/pedal-extenders/index.html
3. Easy-rider Pedal Extender Model CXLB1615-B
http://www.pedalextenders.com/transaction.php
What do you all think?
I would go with Easy-rider Pedal Extender ... since they fabricate them to you and aren't a universal knock-off that could fall off.
The first one is specifically designed for Mustang clutch pedals and most likely won't work for ours (since there is no rubber pad to remove).
I would say to get them installed by the dealership ... yeah ... it is extra money ... but they will make sure that the extensions don't interfere with anything, and you can keep the service receipt to cover your ass in-case some clown tries to play you at fault for an accident because of the pedal extensions (because some jerk will probably try it).
The easy-rider is too easy to install: http://youtu.be/gtrwW-kQWas
Are you sure the rubber pedal cannot be removed?
