ECO vs Non ECO
Not that keen on all the technological details but basically, electric control of valves. Valvematic (vs VVT-i) allow continuous control of valve lift so the throttle valve remain open most of the time, reducing pumping loss. The compression ratio is also of 10.6/1 (vs 10.0/1).
Shok
Eco engine is 2ZR-FAE (non eco is 2ZR-FE) which has variable lift aside from dual variable valve timing. It alsp has higher compression as previously mentioned.
