Engine swap
i have a 1989 Toyota with a blown motor and 1990 with a good motor. My only question is what's the best way to pull the motors. I don't know Toyotas well and it's very overwhelming for me. Thanks
not to be discouraging . . . you best get competent help if you expect to complete this project. This will not be an overnight job.
good luck . . .
Engine Swap is not an easy job. Electrical connections are the main problem. Also check both the engines and transmission is exactly the same. If there is slight difference you may be in big trouble.
