I have a shorted wire somewhere causing a parasitic battery drain.  I noticed some smoke coming from the dash after I replaced the gauge fuse so I pulled the gauge cluster out.  I noticed one of the wires on the back circuit board was burnt so I replaced the cluster.  The gauge fuse blew again with the new cluster installed so I know the short is somewhere other than the burn on the back of the actual cluster.  After blowing a couple more gauge fuses trying to fix the issue, the same wire on the new cluster started burning in the same way.  I followed the burnt wire back under the dashboard (behind the stereo) but I'm not sure how to get access back there to check further for shorts.  Any help would be appreciated!
Based on the included picture of the back of the gauge cluster how do I find out where else to check for the short?
http://imgur.com/NB0z1kb
My gauge fuse blows seconds after turning on the car.
My battery, alternator and starter all test fine.
Parasitic battery drain when the car is off.
New gauge cluster.
New gauge cluster.
