Hi and thank you in advance for any help you may be able to offer
I have a 1998 Corolla that is blowing the Gauges fuse. As the Gauges fuse is in-line of the charging systems, it causes the battery to run low. The battery is new and I replaced the alternator. A repair shop said they checked wires for ground faults and they think its the integration relay that has failed, but said they could not get the part and seemed reluctant to fix the car.
Anyone have experience with this sort of problem? Any idea on what else I should look for?
I currently have the lower dash removed, but have not found the integration relay yet. I believe its behind the same panel as the gauges fuse?
Thanks
Randy
Thanks
Randy
