Hi
ToyBoy
Any name brand 0-20 w oil should be just fine . You will probably get a lot of opinions . I personally use either Pennzoil Ultra or Mobil in 0-20w but would not be afraid to use other brands.The key is to change at or before recommended oil change requirements .
ToyBoy
PS Jan , check your oil level often to see if you are running low on oil and keep it topped up to the fill mark on the dip stick , but don`t overfill . Jim
