HIGHEST MILEAGE 11TH GEN.
I just broke 16k miles on my 2017 Corolla iM 6MT. You don't reset your "Trip A" at every fill up? That way you can track your MPG fr each tank. I reset my "Trip B" at every oil change so it's easy to track.
2015 Corolla LE bought new june 2015 Ontatio Canada.
I only have 95,000 kilometers on mine. Thats about 56,000 moles
Only problem was the squeeky suspension some have noted here.
Solution that worked for me was to spray silicone on all bushings and rubber mounts.
Just turn wheels out on both sides to access the various joints.
Previous corollas and one yaris Iv had did same thing.
Silicone doesn't harm the rubber.
Its worked for over a year now.
Sand salt gets in rubbers and it grinds plus the rubber bushings dry out.
Ph769
Can you upload pictures of the joints?
Just google corolla front suspension pictuers.
You will get lots of pictuers.
If corolla still squaks in suspension after spraying front end. Dont forget to spray some silicon up the spring ( lower strut housing and on top of strut ( lift hood ) , may be because you have high mileage say 100,000 miles+ .
Then you may need to replace some frt end parts, jiggle them to see if their loose ( bushing may be gone )
If your not qulified to take on the task find & stick with an honest mechanic.
If you find the job to expensive, & depending on overall condition of the vehcle you may want to trade your Corolla for a new one.
314k cvt just went out swapped out used one with 110k everything good now!
Was 314k kilometers or miles and was that with or without regular CVT fluid changes?
You couldn’t find a used CVT with less than 110k on it?
How much did the used CVT cost with parts and labor?
I have a 2017 Corolla SE CVT with just shy of 122k miles, mainly all highway with like 4 months I was doing Uber, no major issues at all. To date I’ve replaced the CVT fluid twice, coolant, tons of oil of course and a front left wheel bearing. I am going to do brakes and spark plugs soon. Great little car even if “car guys” hate the CVT. IMG_2381.jpeg
