How can the daytime running lights be disabled - 2013 Corolla
Hello. I have a 2013 Toyota Corolla. My car has DRL's (Daytime Running Lights) that cannot be shut off when the car is running. I replaced the bulb with a LED bulb so that the high beams are brighter and since it is the same bulb used for the DRL's they are a bit brighter also. My question is how would I possibly stop the DRL's from working only? I read there is a wire somewhere that has to be disconnected that controls the DRL's.
Can be turned off using TIS techstream if you have the OBDII adapter and software
(20$ ebay items and beater WinXP laptop, not 64bit friendly)
