Alright, so here's the situation:
My main 2017 Corolla LE key got slammed in an apartment door (Accidentally, of course) and bent. I tried to see if I could still open the front door of the car manually with it, but I couldn't.
A bit later, I came out with the "backup key" (Not used since I bought the car in late 2016), which also could not open the door manually (i.e. key in lock), despite being undamaged, but which could manually turn on the ignition.
My immediate conclusion was, of course, that trying to get the door to work with the broken first key broke the door lock mechanism on the door itself, and that this was the reason why the second apparently identical key couldn't open it despite being undamaged itself (I was able to get in to test the ignition because the remote wireless entry thing still worked on both keys).
However, a friend mentioned that some Toyotas have what are called "valet keys" that may look similar or identical to the master key, but actually be able to do some things and not others. If this were a valet key, it could mean that my front door lock is not broken and all I really need is a master key replacement.
Both keys look identical to me, built in black fobs at the top, with buttons for door lock and unlock, a button for opening the trunk remotely, and a panic button. When I bought the thing, I thought I was told it was a backup and there is a little laminated thing attached that says backup and includes lots of numbers (I assume these are to order or program a replacement key with).
So, how screwed am I?
Is the backup actually not supposed to be able to open the front door manually with key slid in the lock because it's a valet key or something like that, meaning I just need to have the dealership order a new master key? Or is this in every way identical to the original, meaning the door is screwed up now, too, and I'm going to need them to fix the door and order a new second key on top of it?
These are the only two keys that were handed to me when I bought the vehicle new.
