LED Info
hey everyone, I'm looking at swapping out all my lights with LED's. I already have led switchbacks that look beautiful and fog lights on the way. Just looking to see what everyone has on their rears, interior, etc. If you have a link I'd appreciate it!!!
...you knew I'd have something to say!
I only trust Phillips. I know they are DOT approved, not saying others are not.
I have LED's in all the interior fixtures, stop lamps, reverse lamps, tag lamps, side marker lamps and fog lamps. Headlamps you know.
I haven't done the high beams or any of the turn signals.
Most everything I have came from Amazon or eBay.
Auer Automotive for the fog lamps.
I'll see if I can find where I purchased them and provide links.
Philips Xtreme Vision 360 LED W5W T10 194 168 (4000K) (Pack of 2) https://www.amazon.com/dp/B00OYT11RE/ref=cm_sw_r_cp_api_8siszbW92TAHS
Philips 30mm festoon Bright White Interior Vision LED light https://www.amazon.com/dp/B00P2D3W00/ref=cm_sw_r_cp_api_Xtiszb48TJEDG
Philips 127916000KB2 Vision LED Car Lamp, 194 LED / T10 White 6000K, 2 Pack https://www.amazon.com/dp/B017VORB7M/ref=cm_sw_r_cp_api_suiszbG467TF6
That's as far back as I can go in my order history. The stop lights are 7443, I think.
Also, I went with 4k over 6k which seems too bright for my taste. I only used 6k in my trunk.
And oh yeah, did you need resistors? Or only for the turn signals and 7443
I haven't needed any load resistors so far. I think they're only needed when changing the turn signals. Which is also why I haven't done mine yet. I haven't found a plug and play load resistor that I like well enough to purchase. Lol.
I appreciate it @Chris Denton i want one of those retractable license plates if ya want to hook a brotha up!!!
I wish I could. It's a cool mod, but too pricey. I think I paid $120 for it, last year. Really it's only worth about $49.
Comes with two remotes and that's the only way to operate it. Would be nice if I could add a switch or connect it to car power. I could possibly hack the remote but don't have time to mess with it.
be Careful i Attempted a similar Swap like you i Literally bought all LED bulbs for Taillights, Signals, reverse lights, Brake lights and even side markers!......a couple days into using all these LED's plugged in the fuses for my lights ended up blowing( and mind you i did my homework and bought quality bulbs came out to about 135$ for all on amazon) if you install them right by wiring additional harnesses to stop hyper flash and send correct current to the lights it shouldn't be a problem but i just did the plug and play method. The only LED's i never had a problem with where the foglights, those have never blown and they have been on for years.
Oh and i had to take the car to dealership to get fuses replaced. :/ and i returned all the LED's except my foglights.
