Lowering $ Tire specs
Discussion in '2014 + Toyota Corolla' started by Slatemeta, Apr 15, 2018.
  1. Slatemeta
    Slatemeta New Member
    I’m going lower on d2 springs and put xxr18 x8.5 wheels. What tires can I go with 215/40 or 225/40? Will I rub?
  2. Corolla Forum Sign Up!
  3. tnoutdoors
    tnoutdoors New Member
    I’ve seen quite of few people lowered on 18s with the 225/40s. D2s are pretty low so I can’t speak on them though.
  4. Tcazes
    Tcazes New Member
    Bro.....no one will be able to help you without knowing offset/backspacing..
  5. OP
    Slatemeta
    +33 offset not sure on the backspacing. First time going lower the car. Thanks for the replies
  6. Jake
    Jake New Member
    Willtheyfit.com
    Chris Denton likes this.
  7. Chris Denton
    Chris Denton New Member
    I’m on 225/45/18 tires
    18x8.5 rims at 35mm offset
    Plenty of room to spare
  8. SuperchargedMR2
    SuperchargedMR2 New Member
    225/40R18 tires are the correct size and diameter. There should be no rubbing issues.
  9. SuperchargedMR2
    The proper diameter tire is 25.0". The 225/40R18 is 25.1" in diameter while the 225/45R18 is 26.0" in diameter. The 225/45R18 is way too big in diameter.
  10. Chris Denton
    I know, I know, we’ve already had this conversation! LOL !!
  11. Rylee
    Rylee New Member
    I have 225/45 17 on d2 springs and it dosnt rub put 25 mm spacers on and had the roll the fenders
  12. OP
    Slatemeta
    Any input on the d2 springs? I’m at 40k miles and was wondering if I should be ok to lower with out killing the stock suspension quickly...
    And thank you all for the input on tires.
  13. Rylee
    Rylee New Member
    I put my D2s on about 20k still ride like the day I put them on now at 70k
    klebinek likes this.
Share This Page
