power locks
it is doing the same with both key fobs, since both is doing the same I would think it would not be the battery. also the power door locks are working fine. it is just when I use the fob.
You have a defective door lock actuator. The motors stick and they become intermittent when they start to fail. It will die eventually. Common problem. Try to replace it yourself if your mechanically inclined. The dealer charges $600.
