Use long bolts on back cross motor mount frame member in order to drop it far enough holding it where you want with a floor jack until you can put the motor mount back on the frame without a big bloody hassle. I have discovered over the years you can apply the same method in order to pull back anything else on machinery if there is an open access to move.
Eg: keeping car dashes from falling in order to do heater cores.
No one I've ever known has every mentioned this idea.
