Replaced Headlight Bulb and Now
I pulled the battery to replace the headlight bulb and now the 2008 Corolla with 144K run like crap. It stalls at idle. What did I do and how can I fix it????? Jay
No need to disconnect the battery to replace a headlight bulb.
Disconnecting the battery has re-set the vehicles onboard computer and although I've never heard of one stalling before, (which seems to indicate another unrelated problem), however it is possible that with resetting the onboard computer that the vehicles needs to relearn driving patterns, etc. Drive it for about a bit and see if it clears up. In the meantime, make sure you didn't accidentally knock loose a vacuum line, as this can cause stalling too.
Thanks Scott. It's getting better. I did need to remove the battery to access the drivers side headlight. I think. My hands are way to large to fit in that small area, or is there another way to access the bulb? Thanks
