You shouldn't have to reset it after tires rotation. The sensors/transmitters remains the same and the Corolla system isn't wheel specific.
If the light remains on, then one of your tires is on low pressure or there is a problem with the system.
If you install new sensors/transmitters, then you have to "introduce" them to the system (the manual says it's a dealer procedure but there is certainly a way that I don't know of).
If you install new wheels without sensors/transmitters (like my set of winter tires), you simply have to live with the light on !
You use the "reset" button (upper left part of the glove box) to enter a new reference pressure (different than what was set from the factory) :
From the manual :
· Park the vehicle in a safe place and turn the engine switch off. Initialization cannot be performed while the vehicle is moving.
· Adjust the tire inflation pressure to the specified cold tire inflation pressure level.
Make sure to adjust the tire pressure to the specified cold tire inflation pressure level. The tire pressure warning system will operate based on this pressure level.
· Turn the engine switch to the “ON” position (vehicles without a smart key system) or IGNITION ON mode (vehicles with a smart key system).
· Press and hold the tire pressure warning reset switch until the tire pressure warning light blinks slowly 3 times.
· Vehicles without a smart key system: Wait for a few minutes with the engine switch in the “ON” position and then turn the engine switch to the “ACC” or “LOCK” position. Vehicles with a smart key system: Wait for a few minutes with the engine switch in IGNITION ON mode and then turn the engine switch off.
