Shaking when in gear not at idle
Hello
I've read alot of theories that can cause this. I have a 1999 Corolla with 190000 miles it's an automatic
and it's the VE version.
I first changed the plugs and plug wires and it still vibrates when put in gear
I changed 3 of the motor mounts they did look well worn but still vibrates. I didn't do the rear mount
as it's a little harder to get to.
Then I changed the 2 coil packs and it still vibrates. Someone said it may be the fuel pump
I thought I had better ask before doing anymore on it.
Any ideas what to try next?
Hello
try just changing your transmission fluid ,unstable fluid will cause shutter.
