TOYOTA Techstream Ver.10.30.029
TOYOTA Techstream 10.30.029 is released and verified working.
Free download TOYOTA TIS Techstream 10.30.029 software:
https://mega.nz/#!qUoSRLZL!cGn74vplgBIsPy0II2PpBYIGtbuP7SLoSgKgpDOD7iE
password: autoprofessionals.org
Software version: v10.30.029
Multi-Language:English, French, German, Italian, Japanese, Spanish
Techstream compatible hardware cables:
The software interface supports Techstream (Mangoose VCI, MINI VCI with 16 pin cable, Mini VCI 22-PIN, Xhorse MVCI, VXDIAG VCX NANO for Toyota etc) for Toyota, Scion and Lexus makes.
Techstream O/S requirement:
XP or “XP Mode” in Windows 7 (except win 7 home)
A part of users use VMware and XP Professional.
Toyota Techstream 10.30.029 software display:
How to active Toyota TIS techstream v10.30.029?
Open IT3System.ini
C:\Program Files\Toyota Diagnostics\Techstream\ Env\IT3System.ini
Change TISFunction=1 to TISFunction=0
Save
All ok
How to connect Techstream?
USB port plugs to laptop, the other end goes to the OBD2 port.
NOTE: You can put on top of the installed versions or from scratch.
How to install MINI VCI Toyota Techstream V13.00.022
Toyota TIS Techstream V13.00.022 software has been tested and verified working great on Windows 7.
Software version: V13.00.022
(It’s crack version. Does not need activation)
Operation system: Windows 7 32 bit
Toyota Teschstream v13.00.022 has been tested OK with:
Mini VCI cables (SV46-D, SV46-B), Mangoose VCI (SV46-C) and Vxdiag Vcx Nano for Toyota
How to install Toyota Techstream 13.00.022 software?
Step 1: Install Setup
Open Techstream V13 software CD
Copy and paste MVCI driver and Techstream_Setup files to desktop
open Techstream_Setup_v13.00.022 application
choose a setup language for installation
preparing setup
Click on Next to install setup
Accept license agreement
Click on Next
Enter the user name and company name, then Next
Click on Install
Finish Setup installation
Step 2: Install MVCI drvier
Run MVCI driver for TOYOTA TIS SETUP
Next to install MVCI driver
Click on Install
installing MVCI driver
Finish MVCI driver installation
Step 3: TIS Loader
Copy Toyota new genkey folder->Toyota->TIS loader and paste to C://Program Files/Toyota Diagnostics/Techstream/bin
by following this way:
Right click Techstream on desktop->Properties->Open File Location
Send TIS Loader to desktop
Delete Tecshtream shortcut on desktop
Step 4: Install device driver
Connect MINI VCI usb interface with computer
Windows detect device driver automatically
Open MVCI Firmware Update Tool->Device Info to check firmware information
Firmware version: V1.4.1
Step 5: run Techtsream 13.00.022
Open Toyota TIS loader shortcut on desktop
Accept Java runtime notice by clicking on Yes
System will open Windows IE explorer, close and ignore them
Run Techsteam v13 software and start diagnostic
Free Download VXDIAG VCX NANO Toyota Techstream
VXDIAG scanners Toyota Techstream software V14.00.018 (02/2019) has been tested and verified working no issue. V14 software supports Toyota diagnosis till 2019.
Free Download VXDIAG Toyota Techstream V14.00.018
https://mega.nz/#F!SAR3Qa7B!N61Ikd1HKEodTiwpODLXKQ
Free Download VXDIAG Toyota Techstream V14 patch
https://mega.nz/#F!7VZzBQgZ!wO9Fjk0gfZF-tfv6zQAqzw
Year: 02/2019
Version: V14.00.018
Operating system: WINDOWS 7/8/8.1/10 x32/x64
Region: All regions.
Language: English, Spanish, Chinese, German,French etc
Compatible devices: all VXDIAG scanners, VXDIAG VCX NANO Toyota, VCX Pro, VCX PLUS and VXDIAG Full
(The software does not test with other devices, mini vci, mangoose cable etc)
With the latest driver update, there're problems with running the program itself and half of its functionality doesn't work. To get rid of this problem you'll need to clean your Windows registry. Here is a list of best free registry cleaner for Windows. After cleaning the registry, reinstall your driver and restart your computer, and this problem will disappear. I don't know why it occurs, but after contacting technical support, I was prompted to do so. Have you ever encountered a similar problem after updating your program's drivers?
