I thought I start to work on the fuse box under the hood, and use the inverter fuse, 15A. I used a Piggyback? Funny how it has a one -way direction, and it is turned on by the Ignition. This is the one in the center under your armrest of the 2010 corolla S.
Each time I went to put the piggyback I have I had issues where there is a two fuse slot, and believe one is for a spare. the Fuse, needs to be again facing one direction, and which way it is is in the way of me closing the box.
Here comes the funny part. All is now correctly in and it will be ON in like it is a battery On all the time. This piggyback is the next fuse up of these Mini fuses. they have a longer connector end.
I do not need to show the position of the fuse looking from the pass side to the back the fuse is on the upper right only one @15A nothing on each side .clearly marked inverter fuse?
SO back to my old way using a Lipo bat to operate my product and I guess I will go buy a dual cigg outlet adapter and put to the inverter port instead of trying to DIY figure it out.
Here are some pics of the fuse box and all.
Never Failure just a challenge FISH
