What should you pay attention to use 2015 FVDI abrites?
Now 2015 FVDI have released on eobd2.fr. It new adds dongle. Software is more stable than ever.
Compared with old version, software is not made together, new hardware needs open the software authorization. We will ask factory to open the software based on your needs before delivery.
What should you pay attention to when you use FVDI?
1) Before delivery, we will open the software authorization for the FVDI you ordered.
2) When you install the software, update the authorized vehicle first. Here is the detailed steps:
a, Open your CD, enter folder FWDownloader. Then you will find FWDownloader.exe. Run it.
Got FVDI ABRITES Commander to Toyota Corolla from buyobdii-com
I got FVDI ABRITES Commanderlast week for Toyota Corolla ,i got the new version 2015 fVDI has a USB dongle.don't bought in 2014,because that you have to pay 90USD to buy the USB dongle and return the box to update.
Specifications:
1. K-line ISO 9141 (100 mA) to 24 different pins multiplexed diagnostic connector
2. ISO14230 compliant
3. Single CAN bus multiplexed wire to different diagnostic connector pins
4. Double wire low speed CAN bus multiplexed different diagnostic connector pins
5. Double high speed CAN bus wire multiplexed different diagnostic connector pins
6. CAN bus GMLAN, ISO 14229, ISO15765, J1939, ISO22901 compliant
7. USB interface for PC
8. Supply voltage DC 8..30V
9. OBDII Cable
10. Firmware can be made
11. ABRITES Commander for Mercedes / Smart / Maybach
Warning: fVDI is only compatible with Windows XP.so ,you should be careful.
