Wheel Gap
Was up guys I'm thinking of lowering my car I got 19s but hate that nasty gap. I wanna know what would you guys recommend I don't want to slam the car just eliminate the Gap. I'm looking into Tein coilovers Street Basis I think they're called any way what you guys recommend
Coilovers-Tein
Springs-Tein, Eibach
I'm not sure how many inches it is. It should be the stock gap that all corollas come with, the dealership installed aftermarket 19s themselves and as far as I'm concerned they didn't mess with the suspension
I recommend the TRD corolla springs. They remove the gap in the back and makes the car look so much better
Did it remove the gap on the stock 17s or with 19s? Depending on the tire size OP has on his 19s, OP might end up tucking the wheel and start rubbing on the inside with how large the 19s are. @Munchis21 if you can measure the wheel gap you have, it'd be easier to figure out what would be best for you to get.
What brothabear said.
I’m on TRD springs with 18’s and 45’s, another 1/4” and the rear tires will be inside the wheel well.
The front sits a little higher in appearance but is level.
