2008 Corolla......window washer quite working, wipers are working ok. Window washer fluid is topped off, but when I press washer nothing happens, doesn't make any noise. Any help is greatly appreciated.
Yup what Scott said. First start by checking all your fuses. If all those check out, grab a volt meter and see if you are getting power to the pump. If you are, then it's provably just a bad pump. If you aren't you'll have to do more digging into your electrics.
