First, for safe handling that wont make you slide off the road and crash, make certain you get a matching set of four winter tires. Secondly, you should find a small sticker/plaque most likely attached to the end of the drivers door where it latches to the car, or on the part of the car where the latch itself is, or on any of the other doors, or on the underside of the trunk lid, or behind the fuel door, called the tire placard. This will list the factory size tires and recommended tire inflation pressures.
According to
http://www.tirerack.com/ the tire size is either a P185/65R-15 or a P195/65R-15. Check the tire placard for your car to be sure. If the owners manual for the car hasn't been tossed into the trash, (most people seem to do this for some odd reason), the correct tire size will also be listed in it.
I hope this helps you out.
--B.F.Goodrich T/A Certified Tire Specialist
